Kenwood KDC-MP205 CD Player Logo
A
Anonymous Posted on Apr 07, 2014
COMO QUITAR PROTECT ESTEREO KENWOOD KDC-MP205
5 Related Answers
zzedly
Tygh Duval
  • 300 Answers
  • Posted on Mar 28, 2008
SOURCE: Kenwood Kdc mp205 clock
Press and hold the Menu button until you enter the menu. Then follow the instructions on page 20 of the owner's manual here.
Anonymous
  • Posted on Oct 28, 2008
SOURCE: turn aux on on kenwood kdc-mp205
In order to access the AUX option the stereo needs to be in Standby mode. To do this just hit the SRC or source button until you reach the Standby option. Now hit the menu button and scroll up or down until you reach the AUX on/off option and just turn it on. Hope you find this helpful.
Anonymous
  • 165 Answers
  • Posted on Mar 24, 2009
SOURCE: I have no manual and I need to set the time on a
press the "SRC" button repeatedly to select the standby mode. "ALL OFF"
Press the MENU button for at least one second.MENU is displayed and the menu is turned on.
Keep pressing FM button until the SET CLOCK appears in the display.
Press the FWD button for at least two seconds to enter the time adjustment.
Adjusting the hours,press the FM button to advance the hours,or the AM button to make the hours go back.
Adjusting the minutes,press the FWD button to advance the minutes or press the RWD button to make the minutes go back.
Press the MENU button to end the menu mode.
and BINGO.
Anonymous
  • 31 Answers
  • Posted on Aug 15, 2009
SOURCE: how do i set the clock on my kenwood kdc-mp205 no
If you go to this address you'll see it's available to download. Full manual ; http://www.generalmanual.com/Audio/Kenwood-KDC-MP205-WMA-MP3-CD-Receiver.htm
Rich
Anonymous
  • 6 Answers
  • Posted on May 06, 2010
SOURCE: i have a kenwood kdc-mp205 cd player. how do i
Here is how to set the clock :
Enter standby Mode:
Press the [SRC] button,Select the "Standby" display.
Select clock Adjustment mode:
Push the control knob towards FM or AM, thenn Select the CLK ADJ display.
Enter Clock Adjust mode:
Press the control knob at least 1 second until the clock display blinks.
Adjust the Hours:
Push the control knob towards AM or FM
Adjust the Minutes:
Push the control knob towards |<< or >>|
Exit Clock adjustment mode:
Press the [Menu] button.
That should do it!
2helpful
2answers
COMO QUITAR PROTECT ESTEREO KENWOOD KDC-MP642U
En estos modelos quedan grabados los errores de DC en el eeprom y se tiene que limpiar y estos son los pasos para este modelo:
Mientras que el display muestre PROTECT presiona el y sosten el 3 y 6 y luego presiona el RESET mantelos presionados por unos dos o tres segundos y luego suelta el RESET y despues de uno o dos segundos suelta los otros switches.
El display debe mostrar:
DC ERR
Presiona el 1 y el display mostrara
DC1 ERR
Presiona el 1 y sostenlo por par de segundos y el display mostrara
DC1 OK
Presiona el 2 y el display mostrara
DC2 4
Presiona el 2 y sostenlo por un par de segundos y el display mostrara
DC2 0
A este punto el eeprom ya esta limpio y nada mas presiona el RESET y el disply debe mostrar STANDBY
Espero que esta informacion te sea util y avisa si te funiona
Suerte y saludos
4helpful
2answers
Cant get the protect mode of its a kenwood kdc-mp142
you probably have a bad output ic then, and it needs to be repaired professionally.
2helpful
Why does it say protect on my stereo
Protect is a circuit that is built in your wiring to protect from voltage overloads,surges,static charge s that could result in speaker damage or in audible sound
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
