Display remains in minimize display mode surrounded by black back ground how do I enlarge display ?
SOURCE: Display
It could be a bad screen, but I'd suggest checking the screen cable connector (unplug and reseat it a couple of times). Also, check for any breaks, wear or fraying on the screen cable.
Have a super day!
R-
SOURCE: Monitor/screen
You need to install the correct video driver let me give you the download site along with other downloads to make sure you have everything.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=214330&lang=en
you need to install the first one on that list
SOURCE: Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
SOURCE: THE DISPLAY ON THE SCREEN IS ENLARGED AND DOES
You have to go to the control panel, to display, and settings, and change the resolution back to what's optimal for your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Screen goes black after Windows Vista boot
Hello There is chance of serious problem with the screen of the Your laptop. This problem is often seen in case of HP laptop which are more then 6-7 months old. So if the laptop is under warranty they(customer care) will replaced the screen for free. If not the will charge few $ and provide you with original screen. Please check with the vendor from where you have bought your laptop. Regards Gizokieth
