Toshiba 42HP66 42 in. LCD Television Logo
Troy Carney Posted on Apr 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Large pixel lines all over screen
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Apr 07, 2014
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14989565
Points
237762
Sounds like T'Con fault. Contact any service technician to make it confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
How to fix LED TV
probably the T con board is faulty. T con broad is the one which drive the LCD pixels. Watch the video to identify the T con board.
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
www.electro-medical.blogspot.com
Have a thin green line near bottom of screen
Pixels stuck in the "on" position may revert to normal operation with a little pressure. Use a small piece of tape to show where the line runs and turn your screen off. Slightly dampen a soft cloth and apply gentle pressure to the stuck pixel line. Don't press too hard or you may make the problem worse. The idea is to gently flex the screen material and encourage the pixels inside to shift out of the permanent "on" position. Work slowly, applying gentle pressure along the whole line. Turn the screen back on when you've finished to see the line's response. Repeat as necessary until all pixels are back to normal
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
White spot at the bottom of my samsung sync Master 153v monitor.it is quite disturbing please help in sorting out the issue
is it a large spot or just a pixel??
if it a large spot most likely the screen has been damage in someway, either something hit it and damged the lcd. if it just a pixel there nothing much you can do but replace the whole screen.
the same goes for the larger spot. you just have to replace the screen.
check on ebay for prices you can get a good deal.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
7helpful
2answers
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
2helpful
Dead pixel
Dead pixels cannot be fixed, each pixel is controlled by a transistor that is part of the LCD screen. If it is bad, the only option is to replace the LCD screen.
Black lines appeared on the screen
im sorry but it seems thats the screen had a dead pixel from when you bought it, the dead pixel has then since killed off the surounding pixels and they in turn have done the same. this sometimes forms a line but in some more unfortunate cases the screen can lose visual on both x and y axis's.
unfortuantly your manufaturers warrenty will not cover dead pixels as they are so common and there is a torrerance for them without doing harm, but some times dead pixels can spread.
hope this helps.
kev
Laptop screen issues
This is a bad pixel sensor. Your screen has hundreds of vertical and horizontal pixel sensors on the edge, if one goes out on either end it causes a dead pixel line through the screen. Unfortunately, the only way to fix it is to replace the screen. If you can live with the annoyance, I've seen screens last for years with a pixel line without any other problems.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
