Acer Aspire™ T180 PC Desktop Logo
A
Anonymous Posted on Apr 06, 2014
How to activate bluetooth
I double click bluetooth icon in control panel. Bluetooth nothing happens when you click on settings
3 Related Answers
Anonymous
  • 69 Answers
  • Posted on Nov 13, 2008
SOURCE: I HAVE AN ACER TRAVELMATE
Hi lanny,
This is caused by one of two problems either the button/light doesn't work or bluetooth settings are not configured correctly to allow it to work.
To configure it correctly go to start menu>control panel>Bluetooth and make sure that it is enabled and set to work with that little button. I would concentrate on these settings until i got it to work.
Anonymous
  • 180 Answers
  • Posted on Jan 09, 2009
SOURCE: bluetooth
Regrettably, that model doesn't have Bluetooth installed even though it has the button for it available. It's a bargain basement, bare-bones model and that was one of the corners they cut to keep the price low. It would be available in the higher end models.
Anonymous
  • 40 Answers
  • Posted on Apr 22, 2009
SOURCE: Please anyone solve my problem?
this problem generally occurs with blue tooth devices.
before reinstalling device driver
  1. shut down your system properly
  2. turn on your system.
  3. turn on the switch of bluetooth
  4. now try to reinstall the driver
  5. after installing driver restart your system.
2answers
How can I turn on Blue tooth on asus f102 b note book
Hi Vic,
Step 1Push the wireless button, located on the palm rest or on the front, right or left side of the ASUS notebook or netbook. The Bluetooth icon appears on the screen, indicating that it has been activated.
Step 2Alternatively, press "Fn-F2" until the Bluetooth icon appears on-screen.
Step 3Alternatively, expand the system tray and then double-click the Wireless Console icon -- the blue and white icon with the "i" symbol positioned in the center. Click the Bluetooth icon to activate Bluetooth on the ASUS PC.
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
I try to install many drivers for bluetooth vostro 1015 but every time a pop up message say that the bluetooth is not turn on and i must trun on by fn+f11 but it doesn't work and the bluetooth still turned...
In most cases, you have to manually turn the bluetooth capabilities "ON' in the administrative tools located in the control panel. Click the START button. The go to CONTROL PANEL, PERFORMANCE AND MAINTENANCE, then click the ADMINISTRATIVE TOOLS icon. Locate the SERVICES icon. Double click the icon. To the left, you will see a list of options. DOUBLE click the SERVICES AND APPLICATIONS option. A list will populate showing the SERVICES your computer has. Locate the BLUETOOTH capabilities. Right click this option, go to PROPERTIES, click the DROP BOX menu. Make sure the service is set to automatic. Click apply and make sure you click the START button to begin the service. Your device should work after this.
My laptop have got a build in bluetooth but i dont know how to connect it please help
hi
  • Open your computer's Control Panel center to access your Bluetooth Device settings. Click on the Windows icon or the "Start" icon on your computer desktop's taskbar at the bottom of the screen. When the pop-up menu opens, click on the "Control Panel" link.
  • Step 2 Access your Bluetooth Device settings. When the Control Panel opens, click on the settings link that reads, "Bluetooth Devices." This link will display all of the possible actions and settings you can take regarding your laptop'smag-glass_10x10.gif Bluetooth technology.
  • Step 3 Configure your laptop's Bluetooth technology. Select the "Start the Bluetooth Device" action. The blue and white Bluetooth icon will appear in the Windows System tray within the computer desktop's taskbar.
  • Step 4 Network with another device in order to import and export files. Double-click on the blue and white Bluetooth icon on your computer desktop's taskbar. A Bluetooth dialog window will appear on your screen displaying your Bluetooth technology portal. Click on the "Add Devices" action. You will then be asked if your laptop would like to search for other compatible devices. Click "Next" to proceed. You will be prompted to choose a passkey for the pairing. Create a simple passkey and click on the "Pair" option. When the notification is received by the other device, enter the same passkey to pair the device to your laptop.
  • 0helpful
    Lg vu
    User must be logged in as Administrator or have administrator privileges to modify system files
    Setting up the handset
    1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
    2. Touch the Settings icon located on the bottom of the menu tabs.
    3. Touch the Bluetooth icon.
    4. Touch Turn On.
    5. Touch Settings.
    6. Touch My Device Visibility.
    7. Touch to select On.
    8. Touch Set.
    Setting up the connection
    1. On the PC, double click the My Bluetooth Places icon on the desktop.
    2. Click View devices in range.
    3. If the handset does not appear, click Search for devices in range.
    4. Right click the icon representing the handset and click Pair Device.
    5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
    6. On the handset, an Accept? prompt will appear, touch Yes.
    7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
    8. On the PC, return to My Bluetooth Places.
    9. Right click the icon representing the handset and click Discover Available Services.
    10. Double click the Dial-up networking icon.
    11. When the connection window opens, click Cancel.
    12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
    13. Click the Modems tab.
    14. Click to select Bluetooth Modem and click Properties.
    15. Click the Advanced tab.
    16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
    17. Click OK.
    Making the connection
    3. Right click the icon representing the handset and click Discover Available Services.
    4. Double click the Dial-up networking icon.
    5. Type [email protected] in the User name field.
    6. Type CINGULAR1 in the Password field.
    7. In the Dial field, type *99#.
    8. Click Dial.
    You will now be connected to the AT&T data service
    NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
    3answers
    Bluetooth not showing
    Follow these steps to setup Bluetooth:
    1. Double-click the My Bluetooth Places icon
    2. In the initial Bluetooth Configuration Wizard choose where you want Bluetooth icons to be
    3. Enter a name for the computer, select computer type and click Next 4) In the next Bluetooth Service Selection screen, select services that will be offered by this computer by Bluetooth 5) Click next Next button and then click the Skip button to close the Bluetooth configuraton wizard
    Next you will set Bluetooth Discovery options 1) Right-click Bluetooth Icon and choose Advanced Config from Menu 2)Click accessibility tab 3)Select let other Bluetooth Discover this computer option 4)Click the Discovery Tab 5) Select Look for Other Bluetooth Devices option and choose how often you want to perform this check 6)Click Apply and then click OK to close the dialog box. Now when someone else with Bluetooth comes into range it will automatically connect
    1helpful
    2answers
    Toshiba satellite p200 1fc
    The P200 1FC definitely has blue tooth - just found it!!
    Make sure you're connected to the internet and on the desktop click the Toshiba Assist icon which brings up a 'bluetooth settings' button. Click the button and it installs the bluetooth automatically (and for free!). I can now link computer to phone so know it works,
    Jan
    2answers
    Hi, I have a Toshiba Equium P200D-139. I can see that there is bluetooth software on the system but cant see anyway of turning the bluetooth on. Can you please advise me if my computer actually has...
    Make on your bluetooth you should must installed the driver for it. If driver is ok, Then:
    • Navigate Start -> Control Panel
    • See the Bluetooth icon and double. Then you can make the settings for your devices or other properties.
    • You can also checkout Wireless, if you have this icon double click on it and see if there is any option for bluetooth.
    Thanks
    Iqbal
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
