SOURCE: clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
SOURCE: rangemaster clock
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If
that does not work , then you need to replace the control assembly.
YYou find diagrams and replacement parts by entering the model number
here:
replacement parts and free diagrams
SOURCE: rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly!
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
SOURCE: rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
