Televison & Video Logo
A
Anonymous Posted on Apr 06, 2014
Only showing in black and white - Goldstar Televison & Video
1helpful
2answers
0 when i check it i only get 120 on both when i ground then in 0 when i check the white to black is this right the make is a ge 19.9 hot water heater
You did not post the make and model of the unit. However you should have three wires on a 120 volt heater. Black is HOT. White is neutral and green or bare copper is ground. Anything that you check with a meter connected to black should show 120. white connected to ground across the meter would show 0.
I heard that Clayton Bigsby was based on Dave's grandfather? Is this true?
Yes. Dave's grandfather was born blind. He was born in 1911 in a white hospital to a white woman. His birth father is unknown. According to Dave on the DVD commentary, "My grandfather looked like a white person. He probably was a white person...His dad was either black or white. Nobody knows. He could be white." He was adopted by a black family and he could not see himself so according to Dave "as far as he knows he's a black dude that grew up in the streets of D.C." On the day of the assassination of Martin Luther King, some black people started riots. According to Dave, on that day his grandfather is on a bus and hears a group of black youths threatening a white man. His grandfather thought how silly the white man was to be in a black neighborhood while blacks were rioting. He did not realize that the white man was him. As his grandfather explained to the youths that he was black, one can imagine the confused looks on their faces.
Polarity on charger plug
white is positive and black is negative, you can also verify this by connecting it up to a multimeter if you hook the white wire up to the red lead of the multimeter and the black up to the black lead it should show a positive voltage, but if you hook the white wire up to the black lead and the black wire up to the red lead it should show negative voltage
Jul 22, 2012 • Toys
1helpful
1helpful
I have an outside light that I want this timer to control. The switch box has a black and a white going out to the light and a black and white with the electricity. The instructions show to hook the red...
You posted under ST01C timer which has 3 wires: black blue and red (no white wire)
Your description seems to say your timer has 3 wires: black white and red
These are two different timers
I'm going to give you two different instructions that are dead-accurate for both types of timers above:
1) Instructions for ST01C and EJ500 Intermatic timers with black blue and red
Lets do the black and white with electricity:
The black Hot wire connects to Timer-black-wire
The white Neutral wire connects to white wire going to Load (to lights)
Now the black and white to the Load (lights)
The black to Load (to light) connects to Timer-blue-wire
The white wires are connected together with wire nut
The red wire is capped off, and used only if you have 3-way switching.
Green connects to bare ground
2) Instructions for all in-wall timers with black, red and white wires (except Aube series timers)
Lets do the black and white from electricity
The white Neutral connects to Timer-white-wire and to white wire going to Load
The black wire to Load connects to Timer-red-wire
all three white wires are connected and covered with wire nut
DO NOT CONNECT RED TO WHITE with any model in-wall timer and then turn on power or it can blow out the timer >>> I just did that while experimenting with the Utilitec 0192773.
Red wire goes to Load on all timers, except with Intermatic ST01C and EJ500
The sensor has 1 red, 1 black, 2 white wires?
BROWN = PHASE BLUE = NEUTRAL.
European code.
BROWN = BLACK WHITE = BLUE
Feb 06, 2010 • Garden
Black and white screen on tv when i play my x-box 360
Have you tried adjustign the mhz settings ie: change from 50mhz to 60 mhz as some games will show up in black and white if you have the xbox set to 50 mhz
1helpful
2answers
MSI starcam 370i only shows black and white
You can change your lighting to fluorescent lighting the brighter the fluorescent lights are the better your cam will show up the colours, it worked for me.
7helpful
4answers
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
2answers
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
