I backed up my data and now I cannot access it
SOURCE: Simpletech external 500GB HDD with external power not detected
Windows likes to mess with drive letters. Sometimes if you've plugged in another u.s.b. device, Windows will mis-assign the drive letter. Try this:
I'm pretty sure this will fix the problem. If not try us again at Fixya.com
Note If you do not see Performance and Maintenance,
go to step 3. Performance and Maintenance appears in
Control Panel only if you use Category view. If you use
Classic view, Performance and Maintenance does not
appear.
SOURCE: Simpletech Signature 500gb "is not accessible"
Right click on MY COMPUTER and select MANAGE.
Go to DEVICE MANAGER and expand the DISK DRIVES category on the right side window.
You should see the Simpletech drive listed under there. Delete the Simpletech drive and click on OK. Restart the computer.
Windows should re-detect the simpletech and re-install the built in drivers automatically.
SOURCE: 500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies.
Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
SOURCE: Simpletech pinifarina 500GB external drive - unable to access
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
SOURCE: I have my Simpletech 500gb drive pluged in but
Okay, so it should be picking up with that machine. First try re-seating all cables (power and USB both sides) and also try plugging it into a different USB port. Be patient and give it a few minutes to find it. Let me know whether or not that works.
