I believe its the Bissell 2X Healthy Home. Seems to do a good job cleaning but it just won't draw the water back out. It leaves piles of dirty lint and also begins to expel dirty water. I put the warm water in the bladder hoping that it will draw it back up into the container that surrounds the bladder.
SOURCE: bissell proheat 2x leaves dirty water spots
Your belt for the brush might need to be changed, that or the suction parts is clogged with hair or fuzz, check that clear part of the front of the machine to see if theres anything clogging it
SOURCE: bissell proheat turbo 2x is dumping dirty water onto carpets.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
efdy
SOURCE: How do I put a new bladder in my Bissell ProHeat
heatman101
4q
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
SOURCE: When I clean my carpets and hold the trigger only
heatman101
hfkhg
