0107 0110 0131 0152. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
i wouldn't be worry if:
If the tv just does this phenomena for some seconds specially when there is a change from video analog to digital.
if the tv does the issue only for some seconds and then gets back to normal and stays there for the rest of the day.
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
