Hi i just repaired mine. There was no fuse in it i found the timer control has a tranformer that goes from 240 volt or 115 volt in USA to 12 volts only the on off switch worked .
Did you check the emergency shut off switch? Almost all under the counter dishwashers have a wall switch to interrupt the power. The problem is it can be shut of on accident.
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
I don't know what "the timer? has gone" means. You can't clear the timer or reset it? I would call their support. There is also support in the UK. But you can take a look at the following page:
