When I turn on my Network Printer 12, the Attention light comes on and I get error message: 23 Paper Jam. However, there is no paper jam that I can find. How do I get this resolved? Thank you.
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam. open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out -Door open -Print cartridge missing -Paper jam -Paper sensor jammed -Duplexer error
Solution : After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
try this.... try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
Turn off the printer.
printer back on.
alternative :
Load
printer back on.
alternative :
Load
Step1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step 2 Turn off the printer. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step 6 If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step 7 If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
It means "Paper Feed Error" Check your paper in the tray. Make sure it is seated securely with the guides. Take it out and fan the end of it.
Make sure your printer is set for the correct paper size you are using and that you are attempting to print on that size.
Turn off the printer and unplug it. Open the paper jam door and gently push the paper roller up (forward) until you hear a click.
while you are there look again for any tiny scrap or jam of any kind.
Re-close the door. Plug your printer back in. Restart your computer. Turn your printer back on.
Let me know if this helps! And thank you for using Fix YA!
printer back on.
alternative :
Load
