Battery low indication and shut downs even though they are charged for a day or more with new Ni-MH
SOURCE: Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Testimonial: "Perfect solution!"
SOURCE: canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
SOURCE: low battery indicator
Dear sir,
Welcome to Fixya Customer Support
By analysing your problem it deffinately due to battery power sensor problem.so you can visit nearer canon camera service centre,they replace the sensor.
good luck
Fixya Customer support
chandrashekhar
SOURCE: Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
SOURCE: Canon A720IS flash problem/low battery indicator
Voila fixed.
iIt seems that the battery is low or not powerful enough to run the camera properly. when the camera notices there is not enough power it will automatically shut down. ensure the battery is fully charged up on the charger and then try it. the battery type is
Canon NB-3L and if the camera is a few years old or has been stored for a long time the battery may need to be replaced.
if all these have been done and still the problem persists i would recommend a dealer have a look at the camera.
to replace battery open slider plate on bottom of camera and flip tab to release the battery pack.
I hope this was useful.
