I put a DVD in then it says the parental setting of this player won't allow to play the DVD then I clicked yes so I could play it then it says enter password i never set a password
SOURCE: GPX DPL705 Replacement Battery
You can call GPX @ 314-621-2881 press #2 for parts and accy's. Per their website gpx.com
SOURCE: regional code
1.- TURN ON THE DVD PLAYER
2.- PRESS OPEN/CLOSE
3.- PRESS THE FOLOWING NUMBERS 8888
4.- PRESS ENTER UNTIL SHOW "Region code: 9" (Region Free)
5.- PRESS OPEN/CLOSE
OR
1-Turn on your DVD player.
2-Open the tray.
3-Press 9 five times, you will see a number (for me it was 6, you'll see it on the screen, where the DVD displays all messages, like a blue bar up top) then I pressed 9 a few more time until the number being displayed there turned to a 9, when it does then press enter, now it's region free.
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
SOURCE: GPX portable dvd player does not play on bigger tv with rca cable
You have to buy the $15 video cable from GPX. I tried several differant cables including RCA to S Video as a last resort. They say theirs is propritary and I now believe it!!!
Same problems with my unit. But, try this... I think it worked. First, you can not get to the setup screen for the unit with a DVD in the player. So, remove the DVD first: Unplug the unit, wait a few seconds, plug it back in. Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play. At the Sony Blue DVD screen, select Setup on the remote control. Select DVD setup and get to Parental control. Set a password. This will then take you to a "rating" screen. By setting the rating very high (I set mine for #8) any movie should play without needing the password. With no password set, you can not change the "rating" and hence mine was set at #1 (kids). It seems to have worked for now anyway. Good luck.
