DSC-H5 supersteadyshot
SOURCE: Shutter button popped off & I am out of warrenty.
The fix is so easy I thought of it in my sleep. The button had fallen off our H2 while my wife was taking pictures of dolphins. And you guessed it, the button fell into the ocean. Sony sells the Shutter Button Release Assembly for $18.00 plus tax & shipping. Anyway, the fix does not require you to take apart the camera. Using a rubber jar opener you can turn the little silver ring just a little bit. Use your finger nail and lift it off. Look for the little plastic piece that broke and also the little snap ring. On the underside of the ring that you removed, you'll notice two little feet. When putting the new assembly back together, line up those feet with the two slots, pressing down and turning the ring just slightly should hold it in place. Cranky...
SOURCE: SONY DSC-W100
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear as blurred due to slow shutter speed.
SOURCE: Software for Cyber-shot DSC-W100
I think you DSC W 100 is windows xp compatible. However; you can download your software here: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW100&LOC=3
after downloading install it to your system.
copy and paste the link to the internet browser address bar.
SOURCE: lines in the picture
Quote:
mcomijohns
Rank: Wiz
Rating: 83%, 14 votes
It is a bad ccd it need to be replaced some time you can get lucky by resetting the camera in the setup menu.When you take a picture the image is transmitted throught the ccd and translates the image to the cameras memory. It can be fixed. Or you can upgraded. Some places might offer a trade in value on your camera even if it is broke.
end of Quote: i hade the same problem this guy knows the way of the lcd's
SOURCE: Sony DSC-H5 Cybershot write protection
Camera has a "protection" option for the pictures. maybe it;s active. Put camera on "playback" mode and check the available menus. Also, I guess your camera came with a manual. Read it!
