Wheele will only spin manule to make needle move up and down moter sounds fine
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
SOURCE: I have an older Husqvarna sewing machine (sle 6570
In the middle of the bobbin winding spindle, there is a piece we'll call a "flange". It is spring loaded but sometimes sticks. When it is in the center of the spindle it diengages the sewing machine drive system that drives the needle. Make sure it is not in the center of the flange. You can use a small screwdriver and gently press the flange outward and hopefully you may hear a small click and everything will be fine. Make sure also that the round plastic piece the flange is located in the center of, is pushed all the way to the left, (in you're sitting in front of the machine) if you pull that round platstic "knob" to the right, like you're trying to remove it from the flange, it will pop outward and engage the tranmission for sewing heavy fabrics.
SOURCE: I have a Viking Husqvarna and it seems that the
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
SOURCE: I have a Huskystar C20 sewing machine and the
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
SOURCE: The needle in my Viking 6440 is locked in on the
I'm trying to find a machine similar to yours and have done much research re: the older mech viking sewing machines 6000 series. They are GREAT machines, suffering only from problems such as yours caused by the old "lube/grease" they used when it was made @ factory. In their efforts of making a "never needs oil" mech sewing machine, the grease tends to harden & freeze up the gears & cams inside the machine. You need to have it serviced @ authorized Viking shop as you have to completely disassemble the machines & gears, clean, re-lube, & re calibrate the gears... I understand this s/b ~ $175. Money well spent considering if taken care of your beauty could be sewing for another 60 yrs!
Hope this helps!
