I have a wrench with a car swerving light up every once in awhile but I have no idea what it means and I have no idea what stabilitrak is
{: ) A car swerving light on the instrument cluster is the StabiTrak indicator, sometimes called the traction control indicator. A wrench beside it tells it requires servicing.
Your vehicle is equipped with StabiliTrak, which combines antilock brake, traction and stability control systems and helps the driver maintain directional control of the vehicle in most driving conditions.
Traction control activates when the controller senses wheel spin. StabiliTrak will selectively apply the brakes and reduce engine torque to help regain traction.
Stability control activates when the controller senses a discrepancy between your intended path and the direction the vehicle is travelling. StabiliTrak selectively applies braking pressure at any one of the vehicle's brakes to help guide the vehicle in the direction which you are steering.
When you first start your vehicle and begin to drive away, the system performs several diagnostic checks to insure there are no problems. You may hear or feel the system working. This is normal and does not mean there is a problem with your vehicle. If driving conditions delay system initialization, the STABILITRAK NOT READY message may be displayed. If this is the case, your vehicle does not need servicing.
When the StabiliTrak system is both on and actively controlling the stability of the vehicle, the StabiliTrak light will blink for the duration of the event.
You may also feel or hear the system working. This is normal.
StabiliTrak will turn off automatically if a problem is detected in the system. The StabiliTrak light will come on and SERVICE STABILITRAK will be displayed on the DIC. For vehicles without a DIC, the StabiliTrak light and the StabiliTrak service light will both come on. If the SERVICE STABILITRAK message (or StabiliTrak service light) does not clear itself after restarting the vehicle, you should see your dealer for service.
