How to remove the notification on this windows using cmd prompt
Windows 7 not genuine notification using command propt
How to make Windows 7 genuine using Command Prompt
Press Windows key + R
Now "run" box will appear , in "run" box type CMD
Click on OK
Note : Run CMD as Administrator
Now command prompt will appear
In command prompt type SLMGR -REARM
Hit Enter.
Wait 5-10 seconds
Now a message will appear as shown in image below.
Done !!!
Now your Windows 7 is genuine .. :D
Restart your PC once. Hereafter you won't see the warning message that "Windows 7 is not genuine"
You will need to buy a new product key.
Get new Windows product key Windows Help
SOURCE: Windows
Following three simple steps now you can get rid of the pesky and sometimes buggy Windows Genuine Advantage (WGA) notifications:
1. Reboot Windows in safe mode (hold the f 8 key while booting and you will get the option to boot in safe mode) and then:
2. Open Registry Editor (regedit.exe) and search for wgalogon folder and delete it. You should backup up the registry beforehand, in case somethiong goes wrong.
3. In your windows directory search for files wga* and delete them.
You are done!
Now reboot back normally and continue your work. Windows Genuine Advantage will not bother you anymore.
Note: I had previously posted a tip which requires a third-party executable. Now it is not required anymore. You can do it yourself by carefully following the guide above.
Warning: Use at your own risk. Backup everything before you do.
SOURCE: do u know how to remove virus using command prompt (cmd)
Here is a code that remove autorun.inf
go into your usb or hard drive first write in dos
f:
attrib
attrib -h -r -s
del autorun.inf
SOURCE: how to remove ask for genuine window notification
YOU DON'T HAVE AN ORIGINAL XP
FIRST INSTALL THIS SOFTWARE
http://www.saudizoom.com/attachments/58/683d1209823951-winkeyfinder172_final-rar
RUN IT AND CLIC ON CHANGE KEY THAN CHANGE YOUR KEY WITH THIS ONE D36RK-QDFFD-BTWWY-BT7KK-43MGM
REBOOT YOUR COMPUTER AND START UPDATE
DON'T FORGET TO RATE
SOURCE: I want to remove the Genuine notification warning
you need to run a program which will remove your Genuine Notification warning.
Click here to download.
Download it and run it.
SOURCE: remove notifications of genuine window
The
only way to remove this notification is buy purchasing a product key
from microsoft. if you already have one, just click on activate by
phone and you could speak to someone who would actually activate it for
you. I have provided you with a link on How to replace missing
Microsoft software:
http://support.microsoft.com/kb/326246
If you find that this is information was helpful to you, please rate me
and leave a comment as this will encourage me to do more free work for
you and others. And please let me know if there's anything else I could
help you with. Thank you for using FIXYA!
Best regards,
Junior
