The part that holds the needle and makes it sew is completely jammed. Wont move at all.
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
SOURCE: how to re-insert bobbin shuttle
maybe one of the parts diagrams at the Singer site would help? or us the contact there?
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
SOURCE: needle hits inside of bobbin case.
IF YOU HAVE ANOTHER MACHINE TO COMPARE YOU TAKE THE BOTTOM OFF SLIP THE BELT OFF AND THEN LINE UP THE MACHINE THATS OFF WITH THE GOOD ONE AND PUT THE BELT BACK ON. THIS WILL SET THE TIMING RIGHT..
