My 2 year old TV has developed a horizontal thin white line across the center of the screen from edge tp edge
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Testimonial: "thanks Mike"
SOURCE: PICTURE IS ONLY FINE HORIZONTAL LINE
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
SOURCE: My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
SOURCE: Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
SOURCE: My 4 1/2 year old Sony KDF-42WE655 TV is on its
NEED A NEW OPTICAL BLOCK UNIT AND CLEAN THE DUST IN FANS
