SOURCE: black screen
Did you leave it connected to external monitor for sometime.?
coz, external monitor does not come up until the computer gets to the login screen.
Do you see any activity on harddisk light when switched on ?
If not, the problem is with the board.
SOURCE: FUJITSU FMV-BIBLO NB75M black screen
take it to the service center if you are not expert cause it is an internal problem
SOURCE: Computer Keeps rebooting, all lights on, nothing on screen dv6000
Try reseating both RAM mods. If that doesnt work try booting with only one of them connected at a time. If the unit keeps rebooting like this no matter witch one of them you use its a 99.9% chance its the mainboard. This is cover by an extended warrant.
If the unit is outside the extended warranty and you want to try replaceing it yourself. The partnumber for a new mainboard is 443775-001.
SOURCE: hang up when start with ac power
Has this just recently started happening? if so you could try a system restore to your latest stable operating point.. vista is sometimes known to crash after power settings are changed... you could also try reverting your power settings to their defaults( start / control panel / power )if this dose not work it sounds very much like a hardware problem. firstly i would take your power cord to a local repairer to have it tested to make sure it is putting out the correct voltage and mA.. if your transformer is ok you need to test if your problem is with your hardware or software on the pc.. I would install vista on a separate partition and see if you have the same problem. if your new install of vista works fine when plugged in you should back up your needed files format your hard drive and do a complete new install of vista. but if your new install of vista (on the separate partition)crashes in the same way your trusty old laptop will need repair or ebaying
SOURCE: My NV54 went to black screen then grey tried
Because the machine is new and in warranty i recommend that you contact Gateway to arrange to send it to them for repair. They will take you through a few troubleshooting pointers first before booking it in.
I would not try fixing the problem without help from a Gateway technician as because its new its up to them to deal with and laptops are designed to last at least a year before problems arise but in your case it's three weeks. There is obviously something wrong for it to go down within such a short length of time.
Good luck.
