Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61HOIn general, what you'll need to do is:
- Turn off your computer.
- Power on again
- When you see the splash screen or BIOS menu (and before Windows
starts to load), hit the Delete key.
This will typically either get you into a boot device menu or the
BIOS settings where you should be able to select the device you want to
boot from to adjust the boot order. In other words, your computer may
normally try to boot first from the hard drive
drive.But now you have to select to boot from the dvd drive. Save the changes, and then boot
your computer again, this time without hitting any button and lay the windows disk in the dvd drive. If all goes according to plan, you should soon see a "Windows
loading" message on your screen and press any key to install windows.You can follow the on-screen
instructions to install Windows on your computer.
You also need to make a full format of the harddrive, and reboot again.
Look also in the manual how to setup the bios.
Here is some youtube video that shows how:
http://www.youtube.com/results?search_query=how+to+install+windows+xp&oq=HOW+to+install+windows+xp&gs_l=youtube.1.0.0l10.1637.1637.0.3243.1.1.0.0.0.0.122.122.0j1.1.0...0.0...1ac.2.LqJatFrFwa4When the installation is done, you have to install all the driver for the mainboard.Graphic,sound,chipset etc.
Good luck
