SOURCE: will play cd's but cant read dvd's - NO DISC appears
Could be that the lazer is faulty.try multizoning unit. switch on unit with NO disc inside. press enter,press 84269 and press enter again. unit will switch off.
SOURCE: CD player can't find the disc.
Hey man, I had the exact same problem with mine. What you do is take off the top cover which has 2 screws on top and 3 on back side of top. You'll see where the two parts come together to grab cd and spin it. Well, you should also see a little "eye" lens that actually reads the disc. Clean this off with windex or some time of cleaner. Bam, It works.
SOURCE: disc player does not work
Try using a cleaning disc, run it for about 20 to 30 seconds. If that does not help you do not really have any other options, RCA does not sell parts for the audio equipment anymore. They stopped about a year ago or more. I work at a authorized RCA service center and we can not repair any of the RCA audio equipment because of this.
The problem with your CD player is most likely the laser pick up, when it goes bad it can not read the disc's so it thinks there is no disc in it. The laser pick up is the most common reason for your type of problem.
If it is under the RCA warranty still you can send it to them and get a free replacement, if not under warranty you may as well trash it and buy a new one from a different manufacturer. The RCA audio equipment is not very good quality. That is the reason they no longer offer parts for them, it is cheaper for them to give you a new one than to pay a service center to fix it.
SOURCE: We have the RCA RS2767i
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
SOURCE: dvd player reads no disc and than shows loading
Have you tried other DVD's...you might have a bad one.
If so,,,you may need to clean the laser diode. You'll need cottonless swabs (no lint swabs) and Isopropyl alcohol 99%.
Might be hard to get to, depending on the model, but gently swab the diode lens. Don't saturate it tho.
good luck
Play mode
Press PLAY MODE to cycle
between 1 Disc, All Discs,
Repeat 1, Repeat 1 Disc, and
Repeat All Discs.
