They both have flickering lights and they don't seem to be sealing as well as they should. No obstructions. This morning the lights were ok on both of them but when I returned from work both lights were flickering again.
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
SOURCE: Used chest freezer not cooling
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Check the doors are closing properly. Ice build up around the lip may be stopping the seal making, and making the light switch intermittently open circuit.
