Unable to check the fuse power is there. To the plug Power is there to the plug unable to find the fuse
The main fuse is inside the cabinet near where the power cord enters. When everything goes dead all of a sudden, 99.9% of the time it's the fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
