With an USB-miniUSB cable torught active sinc ( windows XP ) or Sync Center (windows vista and windows 7). The main problem is that you need to install the windows mobile device center. On XP is easy ... insert the disc in youre CD drive and install the software. In Visla you will have to download the Windows Mobile Device Center from microsofts download center ( requires windows authentification and if youre windows is not licensed you will fail to authentificate and so to download the WMDC ) i will make a upload with the WMDC on filefactory so you could install it safely. Works in Vista 7 and XP but in XP you have to install ActiveSync first ( from the CD witch came with the phone.. if i remember right it's the "Getting Started" disc )
http://www.filefactory.com/file/ag7afgd/n/drvupdate-x86_exe this is where you can download the WMDC for PDAs
SOURCE: how i cannect my htc
it is very easy and most amazing you can have the privacy of surfing the net at your convenience without it being costly.
Airtel charges only rs.98 monthly rent for gprs and download of 2GB. thats quite sufficient.
first your GPRS must be activated.
step 1. install microsoft active sync 4.5,
step2 connect your htc device using usb of your laptop.
go to programs on your htc
tap on the internet sharing icon
wait
then tap on connect
it will say searching for GPRS and get and show it is connected.
BUT your active sync will say device is disconnected.
dont worry about this *********.
next click on the internet explorer of your lap top!!!
bingo
there you go surfing peace fully.
SOURCE: I want bpl wap settings for my windows mobile htc p3400i.
SETTINGS FOR BPL WAP ON HTC P3400
SETTINGS FOR BPL WAP ON HTC P3400I
START>>SETTINGS>>under CONNECTONS tab>>CONNECTIONS>>UNDER ADVANCED tab>>SELECT NETWORK>>select MY ISP there>>then NEW>>
"enter name for these settings:BPLWAP if this exist den BPLWAP2
under MODEM tab create NEW
"enter name for connection:BPLWAP
"selest modem:CELLULAR LINE(GPRS)
tap next
"access pont name:MIZONE
tap next
USERNAME:ur 10 digit mobile no.
PASSWORD:bplmmsc
tap finish
under PROXY SETTINGS tab
mark all two boxes
enter proxy server as "10.0.0.10"
den tap ADVANCED
tap on HTTP
server:10.0.0.10
port:9401
username:ur 10 digit mobile no.
password:bplmmsc
click on ok again ok nd again ok
now below screen will appear saying
programs that automatically connect to the internet shud connect using:select BPLWAP or BPLWAP2
thats it ur done woth settngs
now go tasks der it will show BPLWAP
select MANAGE EXISTING CONNECTIONS
tap and hold on BPLWAP and choose connect
