It sounds like it could be: (1) Video track on the tape might be messed up. Or (2) The heads on the camera may be dirty. Or, (3) It may be dirty battery connection. (Most likely, it's dirty heads.)
Solutions: (1) Try playback with a different tape that you know is good. Still nothing?? (2) Run a head cleaner specific to your camera, for about 20 seconds. Remove head cleaner and wait 10 to 15 minutes. Put tape back in and try playback again. This will probably solve it.
Another thing to try.. (3) Turn camera OFF. Remove the battery, wipe off the connectors on both the battery and the camera with a clean cloth. Return battery to the camera.Try playback again.
If these steps don't solve the playback problem, you will probably need a camera repair person.
Make sure you've adjusted the Mix knob correctly. The Mix knob is above the Output knob. Turning it counter-clockwise allows you to hear more of your input and turning it clockwise lets you hear more of your playback. Try adjusting the knob clockwise to get more of your playback feed.
If you're not hearing anything on playback on the camera, try pressing the up-arrow during playback to increase the volume. If you're not hearing anything on playback on a computer (and neither the viewer nor the computer are on mute) then something is broken on the camera, causing it not to record audio.
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Run audio INTO the MD play in the L & R IN jacks.
For playback, run (RCA phono plug cables) from the L & R OUT to your amplifier AUX or TAPE inputs. Try playback working first, then add the record function.
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
My playback of clips is also very quiet (when played on the camera)... I think it might just be the camera. When I play the clips on the computer though the sound is perfect.
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
On my handycam you have to hit the Volume + button while playing back. Everytime you playback it starts volume at zero and you have to volume up to hear anytime you playback.
