SOURCE: Where do you plug the speaker wires into the Dell
the green input is for speakers....look for a small green ring gl
SOURCE: Dell inspiron 530S built-in camera problem.
have you tried going to www.dell.com/drivers and see if you can get a new driver for it
SOURCE: my usb ports dont work on my dell inspiron 530s,
Hi there.. i just got the same scenario when i reformatted mine.
Here's how i solved it:
1 - im using winxp and used restore cd to format it then i install winxp sp3 patch.
2 - download and install latest drivers of my devices from website.
3 - install anti-virus and other software. good to go.
SOURCE: dell inspiron 530s won't boot up and gives me 4
4 Beeps indicates a RAM memory failure. Disconnect power, press and hold the power button to release all power from the motherboard, then re-seat the Memory.
If error doesn't go away, try modules one at a time to find the bad one
SOURCE: how do i unlock my dell keyboard?
Dell Inspiron 530s keyboard unlock
Is the keyboard usb or ps2? If its usb then try another port. If its ps2(Green) then power down the pc by holding in the power button for 8 to 10 seconds. Pull the plug and make sure no pins are bent. Plug it back in and boot back up. This should fix the problem if its ps2. Regards
