SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
