Question about KitchenAid Microwave Ovens
Kitchenaid oven racks fall
My oven is a little over two years old. After I self cleaned the racks no longer fit...they balance and then fall if you try to pull them out. I have an extended warranty but they will not help saying its a consummable product. Kitchenaid won't help because its out of the manufacturers warrany. I've ordered two new racks, but it is the same.
    Top Expert:
  • KitchenAid Master
  • 64,733 Answers
Sorry but FIXYA does not have a rack stretcher .
Posted on Oct 23, 2017
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 71 Answers
SOURCE: Oven works but it no longer is self-cleaning. No
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Hello, Got a GE microwave that will not heat the
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
John Cunningham
  • 6771 Answers
SOURCE: My oven racks are rusted and they look light
I would replace the racks, when it becomes rusty green it is time to get rid of the old and bring in the new.
Posted on May 14, 2012
Looking for info on kitchenaid microwave
Your microwave oven is an old timer in terms of appliance years. It may turn ou that replacement is the only practical solution.
Nov 21, 2013 | KitchenAid Microwave Ovens
How to use a self clean magic chef oven bought 24 years ago
Self Clean Magic Chef Ovens, clean by Nuking the baked on grime etc... As I recall, invoking the self clean (some models will allow you to specify a time - 2 hours for light cleaning to 4 hours for heavy), will ramp the oven temperature up to as high as 900 degrees F (as opposed to the mid 300 norm). YOu probably want to remove any racks etc before hand, and wipe up crumbs etc...
Once completed, and cooled, wipe out the ash that is left over, witha damp cloth.
Apr 23, 2012 | Microwave Ovens
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
How to use self cleaning oven?
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. 3 Let the oven do its work;it will heat for several hours, charring off baked-on .foods
  4. Fast Cleaning
  5. 1 Remove oven racks and place them in soapy water to soak.
  6. 2 Preheat oven to 200 degrees.
  7. 3 Turn the oven off and spray the inside with oven cleaner.
  8. 4 Allow to sit for 10 minutes.
  9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. 6 Dry with a soft cloth.
rate this if it help
Thanks.
Oct 15, 2010 | Microwave Ovens
Our 5 year old oven's interior surface appears to
call kitchenaid and complain they might fix it under warranty or replace the unit,, or possibly heard of this and have a fix i persoonally never heard about it good luck mate
Apr 10, 2010 | KitchenAid KCMS145J Microwave Oven
Sep 10, 2009 | Jenn-Air JMV8208AAS Microwave Oven
New Handle for Maxim 3 oven
Hi All -- I just spoke to a very helpful Maxim/Salton customer representative (1-800-231-9786 is the US #), and the glass door for the Maxim OV-300 is considered a "non-stock" part. This means that it's not in stock, but it is (hopefully ;) possible for the company to order it from their manufacturer in China, though it could "take months." I was able to place an order for the door for $20.90 USD including shipping to Los Angeles. Hopefully if others place orders, they'll really re-make some of these parts! Good luck, Penny
Feb 18, 2008 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
