Pentax K110D Digital Camera Logo
Posted on Oct 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Batteries After charging batteries I load them into camera and nothing happens. I tried standard batteries and things work fine. I return to charged batteries and everything works fine too. Why do I get a problem using rechargeable batteries once they have been charged? The same thing as before. The charger indicates error, charging and ready for each battery. No problem with the charging process that I can tell. The charger is an Ansmann Digispeed 4 Batteries are 2200NiMH. The batteries I tested to see whether camera was working were those supplied with the camera ? Panasonic. My first thoughts were that the batteries were faulty but the charger did not indicate any problems. Problem was noticed after a depleted notice was presented on camera. I had been intending to fire flash when message appeared and all the flash would do was fire a weak buzz of light. The camera is working fine in all other aspects. I had checked power was off before removing batteries and reloading them. I also checked that battery compartment door was closed correctly before switching on camera. All in all, I find the incident puzzling, especially as it has happened more than a few times ready. Since the camera is new I was wondering whether I should have it checked by Pentax. Were I to do so under warranty then I am puzzled as to what my problem is when the camera appears to be working. I am considering to get some 2700 batteries at the weekend and will see how they perform. Regarding other rechargeable batteries I only had some old Uniross 800Mah that will only fire one flash picture before draining. I can think of nothing more to add. Batteries were placed in camera just after charging. First time they were warm an d second not. I have sent a copy of the problem to Pentex and when I hear back I will post what they told me. I am just crossing my fingers and toes that it is not the camera. The odd thing was that when I put the re-charged batteries in after charging them, there was no power available to fire-up the camera. Yet, a short time later, they worked only after I used the batterties supplied with the camera. Before trying the supplied batterties I had left the re-charged batteries out for a couple of hours before trying them again in the camera - and still nothing. Yet after using the Panasonics and switching to the re-charged batterties everying worked fine.
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Sep 10, 2008
Anonymous
Expert
Level 2:
Answers
56
Questions
0
Helped
13358
Points
121
Mmmm.... thats a weird problem :)  Yes definatly try those other rechargable batteries that you where thinking of buying, the batteries could be duds??  other than that, if it is under warrnty send it back to pentax with the batteries and tell them the problem.
Canon Powershot A710 IS dont want to turn on. I change the batteries but nothing happens. Yesterday everything was normal. Any ideas?
When this happened after you charged the battery, a few things can be wrong. The worst that could happen, is the battery did not survive the charging session. Other things:
You managed to put the battery in, but the wrong side around. Almost impossible, but I don't know how strong you are.
There is a bit of dust in the battery compartment. Just a little piece of paper can be enough to block the current.
The battery door / cover, is not closed correct. Every battery cover has a switch that is needed to inform the camera that the cover is locked. When the switch does not work, the camera won't switch on.
So my advice: remove the battery, Look if all contacts are clean and shiny. On the battery and in the camera. Check if the battery is really charged, by placing it again on the charger.
After reinserting the battery, check is the battery cover is closed correct.
2answers
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 • GE Cameras
My brand new samsung s760 camera wont turn on
Charge for 1 hour.
Pull battery's and see if they have power.
If Power is good Make sure they are in correctly
If Dead Replace battery's. ,
The only other thing it Might be, You said the Camera was New, But if the battery's hold a charge the Battery Door might have lost it's Contacts and the battery's won't work without it, It may have been returned to the store before you got it..
My camera wil not start, he does nothing at all, the battery is loaded. What can I do.
Before doing anything else be sure the battery is actually capable of holding a charge. Worn out batteries charge very quickly in the charger. A healthy battery will take several hours to charge.
When a "charged" worn out battery is put into the camera battery voltage drops instantly when the camera tries to start from it - nothing happens in this case.
2answers
Completely dead, no response, had been fine, nothing happened to it
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
2answers
I went snorkeling with my olympus 780sw camera last weekend and was taking photos just fine. It was nearing the end of the battery life I believe and when i went to try to turn it on, nothing happened so I...
I have the same problem with my 770 SW. The funny thing is, some outlets in my house will allow it to charge, some will just make the light flash. I found your question looking for a better solution. Try all the outlets in your house with the charger, I know it sounds silly, but it works for me.
The battery charger seems to work fine. I get a
Have the batteries load tested. If they have worn down past the point of no return then they will not take anymore charge. Then the charger will tell you that they are fully charged.
Place my camera on the charging unit and it starts to charge by indication of the green lights and then in second the lights turn red and it stops charging. I have purchsed a new battery and the same thing...
Run the battery all the way down until completely dead and then try recharging. Nickel metal hydride (NiMH) batteries don't develop a "memory" quite like the old nickel cadmium (Ni Cad) batteries
OR
Try taking out the memory card. I had the same problem, but for some reason I had the memory card out and the green lights returned and my camera charges correctly now
OR
Had the same problem, and like mahav said, it was an issue with how my battery was arranged in the camera itself. Adjust the battery, and hopefullyy that will work.
OR
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Thanks
Have a nice day.
6answers
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
6answers
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
