Find the tensions on your machine. Usually a screw below on the bobbin regulates the top stitches tension. Usually a numbered wheel on top--where the thread is around it--regulates the bottom stitches. YOU NEED TO ADJUST THE TOP WHEEL, test on scrap material, and if looser, you are in the right direction. If it is still a mess. turn the knob to a lower number.
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
SOURCE: can not get the brother XL2600i to stitch the top
Make sure the needle has been properly installed - flat side to the back of the machine.
Thread the top thread with the presser foot up - always.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Hold onto the thread tail at the needle and lower (by hand and not the power pedal) and raise the needle to pull the bobbin thread to the top of the machine.
Take both thread tails under the presser foot and to the back of the machine before you begin to sew.
SOURCE: The top stitch on my machine doesn't seem like it
Hi. I think I know what you mean--the top thread looks like it's just laying across the fabric, right? This is because either the top tension is too tight or the bobbin tension is too loose. (Either condition will look the same.) Try it with a different color thread in the bobbin, you can easily see the bobbin thread cross the top thread on top of your fabric. Here's what to do:
Few things about sewing are more frustrating than stitches that aren't balanced!
Sure hope this helps!
Robbie
SOURCE: Suddenly my brother xl-2220 is
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
SOURCE: E6. Motor locked up because the thread is
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
