For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK". Not only they are easy, but also the printing quality is good. For your better understanding pls check out my youtube video. And will see how easy ink refill can be done.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
If you refilled the cartridges with a refilling kit then this error will continue. You see, cartridges have a chip installed on them and it is programed to calculate approximate ink remaining after a certain number of pages are printed.
For eg, a chip on a new cartridge is programed that a full page takes say .5 ml, then if you print 1 full page or two half pages, it will deduct .5ml from the ink volume. When it reaches zero, it does not know how much ink is in there; it never knew in the first place. Now if you refill it up, the chip just thinks that all the pages have been printed so the cartridge must be zero.
In short, this error will stay, if you are able to print ignore the warning and continue to print until the print quality degrades. If you are unable to print you might have to install a new cartridge. OR if you're luck, you may find a chip reseter on the internet or from the refill service.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Don
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Help no longer needed. thanks
