Question about Onkyo TX-SR606 Receiver
Cannot get old onkyo turntable to turn
Sound goes to turntable and through speakers but actual turntable will not turn
4 Suggested Answers
6ya staff
SOURCE:
Marty marty
  • 883 Answers
SOURCE: no sound from my new (refurb) onkyo receiver
check speaker fuses.
Posted on Jun 10, 2007
Gurudristi
Sachin
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
caroldon
  • 17130 Answers
SOURCE: I hooked up a new
Since the input of the phono is of very high impedance and of high gain it is important that the signal is fully protected from any possible induced stray signals of AC or EMI.
Hence the cables must be firmly in place to the Amplifier til there is no hum. If there is hum and the hum reduces as you touch the output pins the outer ground pins of RCA, then reverse the power plug of the turntable. If this wont improve then a ground must be connected externally.
Hoever if none of these prove it is possible that the shield to the stylus is faulty, the lines of the connecting output is faulty.
Make that the phono of the amplifier does not have any hum with the input removed. If so the preamp has a faulty.
Posted on Sep 27, 2010
When connecting AT-LP120 Audio technica turntable to Onkyo stereo receiver TX-8140 I get distorted sound - the turntable came with set cables installed to connect. How do I resolve this problem
hi,
instead of plugging your turntable into "phono in" on the amp just try a regular auxilary input like aux ,video, or cd. sounds like the turntable output isnt like the old ones and may be just a regular output.
Sep 29, 2018 | Onkyo Audio Players & Recorders
Onkyo TX 8020 Receiver sounds muffled. I have the Onkyo TX 80202 receiver and just bought the Audio Technica AT-LP120 turntable to connect to it. I have the turntable switch to "Phono" (so as to make use...
This sounds like a wiring problem. Perhaps a faulty earth connection inside the lead or the plugs to and from the turntable. Also check the connections to the cartridge, they can become loose or be connected wrong. Say a channel to the earth connection.
Apr 05, 2014 | Audio Players & Recorders
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
I am using an Onkyo TX-8255 receiver with the ION Profile Pro USB Turntable and I'm hearing distortion through my speakers at all volumes. The speakers and the receiver work fine with the radio and the...
The TT should be connected properly for the way it's configured (Line Level Out to any Line Level In OR Phono Out to Phono In) and NOT any other way.
Some background reading:
http://en.wikipedia.org/wiki/RIAA_equalization
Jan 15, 2011 | Onkyo TX-DS474 Receiver
Intermitting sound problems on Onkyo SR-705
Does it only happen when its being stressed (played really loud)? Is it hot? If so, is it well ventilated and away from other heat sources?
Somewhere in here is the answer.
"The AV receiver turns off as soon as it’s turned
on
• The amp protection circuit has been activated.
Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources,
and leave the AV receiver with its power cord disconnected
for 1 hour. After that, reconnect the power cord
and set the volume to maximum. If the AV receiver
stays on, set the volume to minimum, disconnect the
power cord, and reconnect your speakers and input
sources. If the AV receiver turns off when you set the
volume to maximum, disconnect the power cord, and
contact your Onkyo dealer."
That last sentence is misleading. I don't think they actually want you to play an active signal at MAXimum as a test. I think they mean with all sources attached and an idle one selected, like CD, crank the volume knob. If the amp is not in Protection mode you should always be able to detect some hiss up close.
For another thing, if it shuts down only with speakers attached the problem could be outbound at one or more of the speakers. I would isolate that piece somewhat before throwing my hands up and calling Onkyo. Make sure that the speaker cables are not shorting. Disconnect certain speakers and try it again until you figure out which one(s) are involved. Then it could be the speakers.
Apr 16, 2009 | Onkyo TX-SR705 Receiver
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Remote Speakers
Hello, I am sorry about your issue. I suggest that you contact Onkyo product support at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA.
Mar 29, 2017 | Onkyo TX-SV525 Receiver
Onkyo TX-SR606 Receiver Logo
35 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
