Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
Probably location from Wifi router. I know some of the areas of my older home don't receive a good signal. Check your wifi bars and see if this is a problem due to only one green bar showing as a connection. Rich
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
Avoid resetting to often your tablet. This makes the system worse. May be you are running to many operations at the same time the tablet cannot handle. I advise you close the task before you start a new one.
Shut it down and then power it back on to reset it. Then turn your WiFi on and scan fir networks, if your network isn't showing up be sure it's set as it should be. It's one if the two. Reset both if necessary. It may take a few tries but you'll get it, if not contact their customer service directly and they'll help you troubleshoot it!
