Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Hi I would check the plug to see if the wires have come loose or the fuse is gone in the plug this can happen at any time and its the last place you always look, the plug looks fine but
I have the same problem "no power at all" when plug into the power wall inlet. No lamp on, display is blank/no led of 7 segments lit, nothing. The door can be opened and closed normally. Holding Delay and Extra Rinses buttons when power on the electrolux EWF 1074, doesn't help either. The electricity wall plug in is active. What can I do more ?
Im sorry to say that you will need to cal the AEG engineer for a quote as the display cannot be black, it should display some information on start up anyway eric
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
