Need to unmute ringer
Enter the model of your VTech 5.8GHz phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
SOURCE: my Vtech 5.8 cordless phone says ringer is off.
press and hold menu button. Find ringer, push up button to change ring volume.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: how to unmute ringer and speaker phone on a VTECH
long hold on hash key, had this prob and just fixed it on my vtech :)
