Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
A
Anonymous Posted on Apr 04, 2014
How does afrost free freezer work - Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
My freezer is heating up?
Because a freezer only does one thing and that is freeze things, unfortunatly any things that breaks on a freezer causes the same thing. Is it running, does the fan work (frost free) are the shelves melting (non frost free) can you hear the compressor running , is the condensor fan running ?
1helpful
2answers
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 • Freezers
1helpful
My freezer of frost free creda fridge freezer is not working. What could be the problem?
ther is a small fan in the freezer that keeps air moving, that is what makes it frost-free, the fan is probably burned out
Jan 31, 2010 • Freezers
Freezer don't get cold-fan turns on ,timer is ticking,black thing under is vibrating,coils are clean
1st check the compressor working or not working .OK compressor is working system gas leak ,not working check the capacitor and timer contector
Frost free freezer
Hi, It sounds like the defrost drain is plugged. UNPLUG the freezer. Remove the rear panel and you will be able to find the drain hole and remove the ice. Once you get the iceout of the drain. try and fluxh it with hot water (A baisting serigne works great). Sometines they plug up with duse from underneath. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
1helpful
2answers
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 • Freezers
Freezer alarm is going off and water is coming out below our frost free freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Frige freezer
possibly due to not defrosting. take off rear panel in freezer and check if there is ice build-up on the evaporator. if so, melt off carefully with a hair dryer and appliance will then work. get back to me with what you find if you wish
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
