I want to erase my hard drive and reload it from the installation CD
SOURCE: dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
SOURCE: Dell System DV051 Not working prop. after storm
I believe this is due to Media Direct requiring a 2G hidden partition and entries in the MBR. As I understand it you have to boot from the Media Direct disc first for it to recreate the partition assuming it has been deleted then install your OS. If you do not want the Media Direct then you should be able to use the OS disc recovery console to repair the MBR.
More info can be obtained from the Dell Forum
SOURCE: Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
SOURCE: Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
SOURCE: Hard Drive Upgrade
Yes, the motherboard should support that size drive with no problems. You will have to reinstall windows using the discs that dell sent you originally. Be aware the drivers for dell can be tricky to reinstall.
