There are a couple of dozen reasons the check engine light is doing that, so the best next move is to find a way to read the codes that are being thrown by the computer. It may be minor, and probably is, but there are major problems that will cause the light to come on as well. I would take it a trusted marina with the tools. I am including a link to a good discussion I found about this ... Good Luck Evinrude System Check Check Engine Light The Hull Truth Boating and...
the idle circuit in the carby still has a blockage that is preventing it from allowing the fuel through
compression is good
possible that the ignition timing is not correct
at this point I would suggest that the carby be overhauled by a Evinrude service shop as rubber from hoses , fuel pump breaks down and fine particles get into jets and passages and block up the holes
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
You can get rpm data by searching your browser using "90hp Evinrude Specs" or "1982 90hp Evinrude idle specs". Changing the jets usually costs you performance on one end or the other. If you have needle rods, a narrower one will have the same effect as a bigger opening in a jet. But you have rpm limits that you should not exceed. Changing the prop can give you more power over the sacrifice of top end speed.
