Rtd124 home theater system what code would i use to program my uneversal remote
SOURCE: universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
SOURCE: MY INSIGNIA HOME THEATER REMOTE
that remote don't support your insignia , you can get one that supports your insignia and the features of your insignia for about $15-$20
hope that helps and thanks for using fixya!
electech
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
SOURCE: Need remote code for AT&T box!
Have you tried this AT&T code 00858. Motorola set-top box codes include 00476, 01376, & 01562.
You can download Onkyo universal remote
codes with
instructions here.
I hope that helps.
