Sony KDS-R60XBR1 bLINKS 6 TIMES
When I try to look up blink codes I'm getting conflicting info. On this model is the lamp on side of TV? If so 6 blinks is showing as lamp door error, the micro switch the lamp door makes contact with is either not closed all the way or possibly defective.You can try reseating door or check the switch and wiring connections coming off it. You could try temporarily by-passing the switch by making your own short across the plug it connects to.
If the lamp mounts in front 6 blinks is a defective thermal fuse.The fuse is mounted right next to the lamp.From the back you can disconnect the plug for the fuse and check for continuity if its open its bad.
