Tthe tablet is staying too long to come on and I could not get passed the logo for the brand of tablet so I pushed the reset pushed the reset button and now there is nothing only a note saying unfortunately launcher has stopped.
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. RECOVERY MODE OPTIONS
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration: Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
