Televison & Video Logo
T
Theodore Yorkshire Posted on Apr 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hitachi LED slim tv model LE32S406. After a power outage the tv began displaying at the bottom several icons such as Super slim-Dynamic backlight contrast-On/sleep timer-Built in power supply-HDMI and ECO. It will then sequence through each icon and enlarge it as it proceeds. This is very distracting. I've tried using the input and the display button on the remote to delete this but to no avail. Is there a toll free number that I can speak to a Hitachi tech regarding this matter?
Mike M
Level 3:
  • Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
Master
Level 3:
Answers
3349
Questions
0
Helped
686183
Points
16707
2answers
LG OLED Horizontal Flickering + Power off
The model would have helped. Generally horizontal lines in the picture come from a defective panel and the set isn't fixable, you could try replacing the t-con board but chances of fixing it are slim
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
How can I stop the tv from coming on automatically after a power outage...the tv was off when it happened
Try unplugging it to reset. the microprocessor. (unplug, wait 30seconds to 1 minute then plug back in)
I highly recommend a good surge protector for your TV, as these power outages can severely damage & or shorten the life of your unit
What is Sansui 24" LED TV/DVD Combo
LED TV/DVD technology is one of the latest innovations from Sansui. The SLEDVD249 features a super slim LED display that can be placed virtually anywhere in your home.The SLEDVD249 combines the clarity of our LED TV series with the entertainment experience of an integrated slot-loading DVD player. LED technology features a stunning picture quality, a wide range of colors, and an incredible range of brightness. LED technology also features a significantly lower use of electrical energy, which means you'll save money on that costly electric bill.
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
2answers
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
No power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
2answers
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
