Not clear when you have white lines. While looking on the screen or really on a image. Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen. Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Try to hold the camera more properly. Disable flash if enough light is there. Hold on the capture button for a while and dont move the camera until the captured image is shown on the screen for review.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
this is a low resolution camera, so its results may appear fuzzy, escesially if viewed on a higher resolution display/device. try this: set the camera on a stationary surface and take a picture of a static scene, taking care not to move the camera at all while it captures the image. if this looks better than the photos in question then the issue is camera motion ( or available light or motion in the scene) while taking pictures. if it is similar to others then probably the low resolution is not sufficient for your expectations/needs.
it starts like this first indoor ok and outdoor over exposed then indoor pics also when u see them closely turns pink or green in shades then horizontal vert lines appear then completely blank
just check with casio if they have issued service advisory for the CCD failure problem as all others have issued they will do it free of charge
The reason for this is that the auto scene function chooses which ISO (light sensitivity) is needed to have a fast enough shutter speed to capture a still image (instead of a ghosted image). There is no way to change this. You can switch modes to P and specify the ISO you want to use (100-200 will give you a clear, non-grainy image, 400+ will be grainy). To capture a still image in low light with a low ISO, you need to use a tripod. Hope this helps.
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
