Connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls:
1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible".
2. From your Sidekick, go to the Phone application.
3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.)
4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE .
5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name.
6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
