Question about Zynga Texas HoldEm Poker
Konica minolta C284 indentations on paper after fixing takes place no visible bulges on fuser changed fuser unit still indentations are taking place
Konica Minolta Bizhub C353 wrinkles all papers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Nov 07, 2014 | Konica Minolta Minolta Bizhub C353 Copier
My konica minolta has a false misfeed showing at fuser area
Check all the sensors, the sensor in the fuser unit might be broken, common thing
Sep 06, 2014 | Konica Minolta Bizhub C550
Konica minolta c284 indentaions on paper
Sir mam are you sure it is not happening before fixing does your transfer belt (Shine y looking thing inside the machine when you open the right side of the machine) Does it have only one pic finger in the middle is that where the nick is located. I believe you transfer belt is causing it not the fixing unit. Stop a copy before fixing does the nick move on different copies
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 03, 2014 | Konica Minolta bizhub Office Equipment &...
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Fuser on C220 Konica Minolta
Use the setting thick 3 its the catch all for weird issues. make sure the paper is not coated also. if that still does not work you can go into service mode and bump up the fuser temp , its the number 1 button(machine).
Jan 08, 2013 | Genuine Konica Minolta Konica Minolta...
Ihave konicaminolta biz hub pro c6501 machine when i take 300 gsm paper in trailing edge the images getting blurred . please help me
300 serious thickness. Does it do it out of all draws and bypass trays? Certainly will slow the machine down to fuse it properly
Jan 03, 2012 | Konica Minolta Products - Konica Minolta -...
The toner isn't adhereing to the paper, If i change the settings to card it sticks
The fuser unit is faulty or the power supply to the fuser unit is faulty. The fuser unit is not heating up to fuse the toner powder to the paper.
Try re-seating the fuser unit.
Mar 16, 2011 | Konica Minolta Office Equipment & Supplies
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
My Konica Minolta Printer cuts paper
You most likely have a "claw" out of place in the fusing section. These are sharp little spring guided teeth that keep the paper off of the heated roller. If you had a paper jam and pulled the paper out forcefully it can flip these claws out of place, causing it to cut your paper. (or jam more often). To find these claws, follow the heat. They rest on the hottest part of the pressure rollers of the fuser.
Mar 06, 2009 | Konica Minolta magicolor 2300DL Laser...
Zynga Texas HoldEm Poker Logo
35 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Vincent G
Vincent G
rebecca curry
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
