Is it ok to put f5 coil in water during use
Fisher F5 is not applicable for wet sands.Its only use at the beach, dry sands. It's not stable with water because it has lower sens that will lose a lot of depth. https://detectorly.com/demystifying-metal-detector-revolutionary-technologies-behind
Yes, you can submerge the F5 coil and shaft, but not the control housing. The F2 cannot.
Be careful not to slip and fall or drop the F5. As a precaution use a sling/strap that goes over your shoulder and/or clips on you, so if dropped the control housing will stay above the water.
Happy hunting!
Yes, it`s ok to submerge the coil, just hang on to it! You can strap it to yourself for insurance, rifle slings can be easily modified for this purpose...
