Bluetooth pairing mode
SOURCE: bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
SOURCE: Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
SOURCE: HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
SOURCE: how to put motorola bluetooth in pairing mode?
Hi there - follow the step-by-step instructions here:
http://direct.motorola.com/eng/bluetoothselect.asp?country=GBR&am
Just pick your model and it will guide you through it;
SOURCE: pairing bluetooth
Erase bluetooth's memory first. Hold both volume buttons along with call button for 10 seconds. Then shut it off and back on. When you turn back on it will take a couple seconds and will stay lit blue. At that time, you need to go into your phone's bluetooth status and add a new device. The passcode is 0000. Good luck!
