I have the effects plugged into the channel line in, I get signal fine, but when I crank the effects channel, it has no effect.
Are you actually sending a signal to the effects unit? normally you would have it in an insert although I know some people who take a sub channel out to the effects unit and then feed it back in through a mix channel if they run out of inserts or aux busses. What you describe above does not make sense to me. Can you elaborate with the full signal path for the effects unit?
SOURCE: Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
SOURCE: Connection problem
simple bro. . .. flick the korg kaoss pads setting to send . . u will find this on the back. . . i thin you have it set to direct. . flick it over to send and then let em know if it works. . . and could u answer ASAP what cords you used to connect the kp3 to the send return on your mixer. . .thanx
Dj Nap
SOURCE: effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
SOURCE: Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
