It appears the first two steps are the same as for top thread but rather then taking the thread all the way down towards needle you make a wrap around the bobbin tension disc then to the bobbin. There is no hook at the second step, it's just where there thread exits from behind the large plastic piece.
If the bobbin is inserted with the thread spinning the wrong direction this will cause "birdnesting" - thread build up under needle plate, you need to cut thread to get the item off machine. flip the bobbin over into the case and try again. Also make sure you remove ALL thread caught up in "Birdsnest" when they happen.
THREADING a machine can vary from machine to machine. THEN the kind of and quality of the thread will make a big difference. Don't stop with the cheapest thread. Make sure it has poly cotton instead of straight cotton. Some wear the fibers and they fall into the threading mechanism area. Resulting in having to have it taken apart.
Take a look at the manual and make sure you have the bobbin going in the right direction in the bobbin case. Each sewing machine is different. On my Kenmore the bobbin drops in counter clockwise, on my old Universal KAB you have to the bobbin with the tread facing away from you when you slide it in the bobbin case then pull it through the slot and put ut under the tension spring. It is the same for the Brother Lx3125 as the Universal.
Remember the needle bar needs to be in the highest point. Make sure the horn goes into the slot in the shuttle race and is properly seated in the race.
The bobbin needs to be about 5 inches long and your upper tread also needs to about 5 inches long from the needles eye. Hold your upper thread tightly so that when it enters the needle plate hole it can catch the bobbin thread. Pull both of the threads beneath the presuure foot and toward the rear of the machine.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
